#1 |
My upper thermostat housing bolt snapped off in the hole and I can't seem to get it out.
(same problem as http://www.toyota-supra.info/forums/...ead.php?t=6233) Are there any sealants that can withstand coolant pressure that I could use to seal the thermostat on with one bolt below it?
1985 manual (r.i.p) -- 1989 automatic (new) http://www.cardomain.com/ride/2635827 |
A Little Story about a crank bolt | abhattan | MKIII Supra | 17 | 03-28-2013 01:06 AM |
Broken Thermo Bolt | scruffboy | MKIII Supra | 17 | 10-08-2010 01:03 AM |
stripped rear end bolt | 87 Supra | MKIII Supra | 5 | 10-16-2007 02:40 PM |
how do you get to the top bolt on the starter? | TATTOOED87TURBO | Non-Generation Specific Questions | 3 | 02-21-2007 06:52 PM |
Broken Bolt | scruffboy | Non-Generation Specific Questions | 6 | 10-31-2006 01:33 PM |
