Old 09-30-2007, 03:06 AM   #1
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
Default anti-lock brake system abs question
I failed a warrant because the abs warning light didn't come on. I have a repair manual, the workshop manual and a owners manual. However there is a light that does come on, but it displays "esc". This light goes off after three seconds after the ignition key is turned on, and whenever I unplug the abs actuator with the "w" connector the "esc" displays open circuit code.
1990 3.0Ltr GT Turbo @8psi Manual (Converted)
Last edited by linuxgurupodboy; 09-30-2007 at 03:11 AM. Reason: picture didn't come through
linuxgurupodboy is offline   Reply With Quote
Brake question suprabahamut MKIII Supra 4 08-13-2008 05:32 AM
Prop/Drive Shaft, brake question spudz29212MKIII MKIII Supra 13 05-31-2008 07:15 PM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
Cooling system question thunder550 MKII Supra 8 12-17-2006 12:53 PM
Question about an exhaust system 89n/aA/T-2turbo5spd MKIII Supra 0 06-21-2006 02:33 PM
