Old 06-08-2005, 01:56 AM   #1
Supra91_ishot
Supra91_ishot is on a distinguished road
I need help on this really badly. I have a 1989 Toyota Supra Turbo. If anyone had an answer, please help me out.
Okay, my car is starting to have some problems, now I am seeing the "engine light" come on. Whenever I start my car, it doesn't come on, but when I am driving it for a couple of minutes, it comes on. When it is off, the car still drives nicely and still has the same power, but when the "engine light" comes on, the car seems to lose power.
I took it to a shop called "Precision Tune Auto Care". They told me that it's the coolant sensor. They say it's going to be around $280 plus for repairing it. Then, I took it to a Toyota dealership, and I didn't let them checked on it yet but one guy who worked there ask another guy who have worked with Supras before and that guy told me that it's not the coolant sensor, it's probably something else like the wires and ignitions and etc...
Do you guys have any clue what's cuasing this problem?
Remember, when the "engine light" is off, my car drives the same, like it still has power, but when the "engine light" comes on my car loses power. Even when my turbo kicks in, the car is still slow.
Any help would be really appreciated.
Thanks!
Supra91_ishot is offline   Reply With Quote
Old 06-08-2005, 02:55 AM   #2
When the lite comes on, and especially if you have driving problems, you should NOT drive far or often, as a possible cheap fix may cause more expensive damage. Where are you at? In smog cert required states and countries, the smog repair shops can easily diagnose the code set in the computer.
A coolant temp sensor is easy to replace, and cheap enough at a parts house.
Old 06-08-2005, 12:37 PM   #3
sounds like you got code 52.. knock sensor short circuit or fault
http://www.toyota-supra.info/forums/index....ct=ST&f=2&t=333
follow those directions and let us know what code you have
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
engine light on/ and about my RPM gauge cyanide-is-a-way-out MKIII Supra 2 10-12-2007 05:23 AM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
