#11 |
SP58GT
you can put the 2j in tehre but its not much of bolt on like the 1jz is, teh motor is a little bit bigger and little bit heavier..so some extra modification can be done
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
#12 |
What are the differences between the 7m and the 2jz motors?
I mean in the head and in the block its self. I see insane numbers pumping from the 2jz build, which is nifty, but I have a hard time finding information on the motor. For the record, I'm pondering doing this swap for my car, when I find the right one. If for nothing more then the parts availability. I can't find to many things for the 7m(internals and what not). |
#13 |
SP58GT
theyre pretty much totally different motors, the heads flow differently, the stock bottom ends are different...the only thing similar is that theyre both 3L, though its hard to believe u have a hard time finding info on teh 2jz.. its harder finding info for the 7m....
#14 |
ya it is hard to find info on the 7ms i cant find much on them. you should here my supra i just bought the engine is blowen so im looking for a new one thats y im asking all these questions
#15 |
I seem to find consistant problems with getting technical information of either motor.
Materials used in construction, main journal sizes, so on so forth. |
#16 |
i normally search google or msn for info it gets me some info
#17 |
Yeah, I'm looking again and again. Yahoo, Google specifically.
I found the bore and stroke, boost levels, compression levels, ect. A very informative site(http://www.jza70.com/articles/engine...omp_chart.html). But nothing about materials used for construction. I'd imagine its an aluminum head, but don't know for sure. Are the pistons forged? What're the rods rated to? Valve sizes. Haha. Thanks for answering, mang. |
#18 |
doing 7mge to 7mgte swap is a BITCH....the 89 supra had yellow plus for the ecu and the 87 had grey plugs...THUS i had to rip the harness from the WHOLE DASH to the headlights and swap it into my 87....and change the mounts on the 7mgte with the 87 n/a mounts....and im using my w58 tranny temporarly untill i get a r154 turbo tranny....but yeah....thats the swap....
oh shit sry officer....you caught me spoolin.... ![]() |
JDM 6MGE engines avilable | Supra Goddess | MKII Supra | 12 | 03-27-2015 12:32 AM |
7mgte-1jz-mk engines | supraquest | Non-Generation Specific Questions | 2 | 01-07-2009 07:46 PM |
Change the climate cntrl color? | XtreeX | MKIII Supra | 6 | 05-10-2008 01:54 PM |
Why are JDM engines available at all? | finaltable | Non-Generation Specific Questions | 3 | 06-09-2007 12:51 AM |
Should I STILL change head gasket?? | lifesnotfair | MKIII Supra | 7 | 01-13-2006 01:08 AM |
