#6 |
SP58GT
wait...why would u plug a turbo harness into an n/a harness? you'll only need one...once u get the turbo motor you can chuck the n/a harness you wont need it, the turbo motor's ecu should be a bolt on also since you alrdy have a turbo motor and u now have a turbo ecu...no need for modification just rip out the n/a ecu and u can chuck that too and plug in the turbo ecu
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
JDM 6MGE engines avilable | Supra Goddess | MKII Supra | 12 | 03-27-2015 12:32 AM |
7mgte-1jz-mk engines | supraquest | Non-Generation Specific Questions | 2 | 01-07-2009 07:46 PM |
Change the climate cntrl color? | XtreeX | MKIII Supra | 6 | 05-10-2008 01:54 PM |
Why are JDM engines available at all? | finaltable | Non-Generation Specific Questions | 3 | 06-09-2007 12:51 AM |
Should I STILL change head gasket?? | lifesnotfair | MKIII Supra | 7 | 01-13-2006 01:08 AM |
