Old 10-28-2005, 02:50 PM   #1
cody_18_06
cody_18_06 is on a distinguished road
Default change engines
Hi I have a 1986 toyota supra with the 7-mge i want to drop in a the turbo engine in to the non turbo supra I was woundering if some one can give me some info on what difernent on the to engines what need to be changed to do my project, like computer, electrical or so on? An dos the non turbo tranny fit on the turbo engine. if some one can give me some advice or a web sit that would help i would appreciate it.
thanks cody
cody_18_06 is offline   Reply With Quote
Old 10-28-2005, 03:59 PM   #2
SupraMan1784
7mge to a 7mgte is pretty much a direct bolt-on...theres no major electrical work you will have to do...though you might want to get a boost meter now that you have a turbo, teh harnesses are exactly the same...as for the computer...i think u might have to switch them..though i never made this swap it would make sense to since now you have boost...though with a piggyback or a standalone im sure you can tune the na ecu into accepting boost and yes..the na tranny does bolt-on to the turbo motor...both are 5 speeds and are the same...unless you are doing an auto to manny conversion then itll be different obviously
Now: Saving for an MKIV
Broken Rides:
Old 11-06-2005, 04:44 PM   #3
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
the harness between the 2 are not the same, the turbo harness has a few more sensors integrated into it, turbo boost, temp, etc. alot of the sensors have different connectors because of the different parameter of the sensors, differentiating them from the turbo sensor and N/a sensor. the ecu cannot be made to except the turbo boost, different chipset, the ignitor is different, the 2 manual trannys will bolt up but are not the same, the N/a tranny is very weak and synchro's are different and will tear up real quick if you do any speed shifting, which with a turbo ppl tend to do alot. Suggestion, get the harness and ecu and ignitor with the engine your getting. if not, you can get ecu's and harness's on ebay really cheap.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-07-2005, 01:55 PM   #4
SupraMan1784
oh damn good correction...i meant to write the harnesses "arent" the same, though i thought the 5spd for the ge was the same as the gte...i may be wrong again..then again i havent done thsi swap so i wouldnt know
Broken Rides:
Old 11-07-2005, 07:31 PM   #5
cody_18_06
so i would have to rewire the engine or will the turbo engine harness plug into the non turbo harness? and will the turbo ecu plug in or will i have to modify?
Old 11-07-2005, 07:39 PM   #6
SupraMan1784
wait...why would u plug a turbo harness into an n/a harness? you'll only need one...once u get the turbo motor you can chuck the n/a harness you wont need it, the turbo motor's ecu should be a bolt on also since you alrdy have a turbo motor and u now have a turbo ecu...no need for modification just rip out the n/a ecu and u can chuck that too and plug in the turbo ecu
Broken Rides:
JDM 6MGE engines avilable Supra Goddess MKII Supra 12 03-27-2015 12:32 AM
7mgte-1jz-mk engines supraquest Non-Generation Specific Questions 2 01-07-2009 07:46 PM
Change the climate cntrl color? XtreeX MKIII Supra 6 05-10-2008 01:54 PM
Why are JDM engines available at all? finaltable Non-Generation Specific Questions 3 06-09-2007 12:51 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
