Old 08-01-2006, 12:54 AM   #1
Toyotafanatic
Toyotafanatic's Avatar
Toyotafanatic is on a distinguished road
Exclamation Help Major Problem With Car!
Hey guys trying to help my mom out with here piece of shazbot mustang, It has a few problems:
1. Battery dies all the time.
2. stumbles when floored.
3. AC doesnt work.
4. Revs to 2000prm when heater is turned on.
5. Blows cigerate lighter/ auxillery output fuse quite often.
Sounds to me theres a short in the car somewhere beause the battery dies for no reason and the battery is fairly new, for the AC, I recharged it and It worked fine till the next time I started it up the car again, compresser cluth didn't engauge, and a bunch of pressure is held between the condensser and compressor? The stumbling is kinda weird, its almost like a cylinder is missing, but theres no check ebgine light, maybe a cloged fuel injector im not sure but all I know is this car has some major problems. HELP ME OUT!
BOOST IT!
Toyotafanatic is offline   Reply With Quote
Old 08-01-2006, 06:13 AM   #2
suprasforlife
suprasforlife is on a distinguished road
The solution, sell it and buy her a supra!
suprasforlife is offline   Reply With Quote
Old 08-01-2006, 06:30 AM   #3
newbsupra
newbsupra's Avatar
Amen! 3 words, ITS A FORD.
Old 08-01-2006, 08:39 AM   #4
Supra2NR
Supra2NR's Avatar
this is another classic example why ford panicd after the supra was made
jus buy your mom a supra get the head done and that's it
as long your mom doesnt wanna got running 15 lbs of boost going to the grocery store,, lol
Old 08-01-2006, 08:12 PM   #5
Toyotafanatic
Thats exactly what were doin just need to sell it first, shes getting a tacoma and Im getting a mighty powerful SUPRA!
BOOST IT!
Old 08-01-2006, 11:04 PM   #6
Toyotafanatic
But I cnat sell it all f**ked up, so help me out!
BOOST IT!
Old 08-02-2006, 01:32 AM   #7
mrnickleye
mrnickleye's Avatar
I guess you need to join a mustangy forum.
Old 08-02-2006, 05:15 AM   #8
Toyotafanatic
I WILL NEVER JOIN ANY KIND OF FORD FORUM!
BOOST IT!
Old 08-02-2006, 05:49 AM   #9
suprasforlife
Sounds like you have a major short. Make sure all the grounds are hooked up and not broke, sounds like the short is in the heating and/or ac system. Does it run ok if the heat and ac is off? Lagging when floored is usually a fuel issue, check the fuel filter make sure its clean, check fuel pump if needed, pressure regulator(s), injectors etc. Does it have the stock stereo in it? If not could be a bad install, if its not stock maybe check behind the stereo and make sure the wires back there did not get cut or pinched or something. Another thing you can do is check the alternator, start the car, remove the positive cable from the battery and if it stays running you know the alt is good, if it dies your alt is crap. Only keep the pos cable off for a few seconds, not good for the alt for it to be off long, about 3 seconds will let you know because it will die right away. Make sure that your ac system is charged right to. The high reving could be from a sensor, check the heat ones first. O2 next. Not sure this helps any but I owned a mustang about 12 years ago and it was an electrical nightmare, did not keep it long.
Old 08-03-2006, 12:17 AM   #10
Toyotafanatic
Yea, for some reason mustangs had electrical problems, It drives me crazy! but i'll try those things tonight.
BOOST IT!
