Old 10-12-2007, 06:14 PM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
Default haha oil pressure
so you know how the stock oil gauge is just not accurate well i went and bought a mechanical one and took like 2 hrs to hook up i finnally fouind a bolt on the side of the block where it looked like oil passed through so i hooked the adpater up to it and i think it works am i rihgt?
cyanide-is-a-way-out is offline   Reply With Quote
Old 10-14-2007, 11:41 AM   #2
IHateHacks
IHateHacks's Avatar
You might be getting a different reading because oil pressure varies throughout the engine. You should replace the stock oil pressure sending unit with the gauge you bought, compare your readings, and use that oil passage for an oil temp gauge.
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
oil pressure johnkarl MKIII Supra 2 11-05-2006 02:11 PM
