Old 05-24-2009, 01:17 PM   #1
craig
craig is on a distinguished road
Default 87 Supra non-turbo to turbo
This is my Supra. Ive only been working on this car about a month. And only have the weekends to do so. More Pictures can be found at http://s710.photobucket.com/albums/ww110/CRS1983/
craig is offline   Reply With Quote
Old 06-12-2009, 04:55 AM   #2
86.5 7MGE
86.5 7MGE's Avatar
Thumbs up Sweet NA-T Conversion!
That's a sweet set up...currently I'm fixing all of my minor things so that my car can get it's hp back and I'm saving to put a turbo on my as well. What I would like to know is what all did you need to do to get it ready for a turbo. And do you have any problems with or during the NA-T application. I was thinking of going with a small turbo so it would be less chances of blowing my engine up what do you think?
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 07-14-2009, 07:15 PM   #3
Beals
Beals is on a distinguished road
Well really if you run any ammount of high boost on any turbo it will blow as the compression is to high. But if you use a stock turbo you should be fine running up to 10 lbs of boost no problem I believe. But you'd definately need all new piping, ecu ect to do this. I'm sure someone parting out a car you could just ask for it all and get a price on it though.
Beals is offline   Reply With Quote
Old 08-26-2009, 08:03 PM   #4
Toyota Fan
Toyota Fan is on a distinguished road
Make sure you swap to the Turbo transmisson or else your gonna be hating life the old tranny cant handle that kinda horsepower I got my second supra and its a non turbo I really looking into a supercharger because California is anal about turbos be pretty cool if I can find one that works or make it
Toyota Fan is offline   Reply With Quote
Old 10-02-2009, 07:33 AM   #5
jeneliachrist
jeneliachrist is on a distinguished road
Good set up with perfect modification you made for your car.Good work done.I really appreciate you for your fabulous work.
Toyota Fortuner 2009 Toyota Performance Chip
jeneliachrist is offline   Reply With Quote
