-   Show n Tell (http://www.toyota-supra.info/forums/show-n-tell/)
-   -   IHateHacks' 87 Supra (http://www.toyota-supra.info/forums/show-n-tell/4888-ihatehacks-87-supra.html)
IHateHacks 06-02-2006 02:32 PM
Well its finally road worthy so I figured i'd share some pics. I bought this car in August 2005 with 120,301 miles on it and it went from this-
http://i44.photobucket.com/albums/f2...e/DSC00346.jpg
To this-
http://i44.photobucket.com/albums/f2...e/DSC00360.jpg
To this-
http://i44.photobucket.com/albums/f2...e/DSC00501.jpg
Ive put 400 miles on it with about 150 of them under full boost and it hasnt used any oil at all, Im actually astonished. It must have been rebuilt before I got it because it uses no oil and doesn't even make the faintest ticking like a 120K mile toyota usually does. Im very pleased with my Toyota!
IHateHacks 06-02-2006 02:37 PM
http://i44.photobucket.com/albums/f2...e/DSC00495.jpg
ddmcse 06-02-2006 02:54 PM
you need a garage with that white one .
looks nice can't wait to run into you in wallingford
IHateHacks 06-02-2006 03:04 PM
Thanks! Yea I find myself washing it every 2 days. Im sure our paths will cross some day.
IHateHacks 06-05-2006 11:19 AM
Im in the process of installing gauges in my supra, I really should of installed an EGT and wideband gauge when I had the turbo off but I was in too much of a rush to complete the job that my mind wasnt right.
Anyways Im installing a water temp, oil pres, and boost gauges and keeping all the stock ones. Its going to be a custom setup since I cant find any gauge kits for 87-92 supras.
Yes I know it looks ghetto but I still have 2 more gauges to install and put a finish coat on my little custom panel.
http://i44.photobucket.com/albums/f2...e/DSC00503.jpg
http://i44.photobucket.com/albums/f2...e/DSC00505.jpg
IHateHacks 06-10-2006 02:01 AM
Just installed the water temp gauge, with a 180 degree thermostat it runs 185-190 on the street and 195 on the highway. Does this sound normal? Still running the stock gauge also. 2 down 1 to go.
http://i44.photobucket.com/albums/f2...e/DSC00511.jpg
http://i44.photobucket.com/albums/f2...e/DSC00509.jpg
projekt6 06-16-2006 03:56 AM
where did you get the piping for you intake??
cars4me89 07-11-2006 06:09 PM
why are you installing H2O temp, oil pressure, and boost gauge when you've already got it on your dash??
IHateHacks 07-12-2006 12:26 PM
Because the stock ELECTRIC gauges are inaccurate and unreliable even after replacing stock sending units, and boost, coolant temp and oil pres. are the most important. I am contemplating installing an oil temp instead of pressure thats why it isnt in yet.
The gauges you see pictured are mechanical. That means there is actual boost going to that gauge and actual hot coolant going to that other one.
j3pz 07-16-2006 09:49 PM
very nice, can see many hours have gone into this car.
on the side, why keep the stock gauges? why not replace them with your new ones?
IHateHacks 11-21-2007 05:03 PM
Update:
Since my well documented BHG. I've installed a turbo back 3" stainless steel exhaust, Tein flex type coilovers, Blitz stainless steel intake, powerslot rotors and a stainless steel braided clutch line.
Here's some recent pics.
http://i44.photobucket.com/albums/f2...e/DSC00656.jpg
http://i44.photobucket.com/albums/f2...e/DSC00658.jpg
http://i44.photobucket.com/albums/f2...e/DSC00664.jpg
http://i44.photobucket.com/albums/f2...e/DSC00667.jpg
ddmcse 11-22-2007 02:08 AM
you got rid of the red car ?
that thing looks great
IHateHacks 11-22-2007 02:15 PM
Yeah I tore the SHO down, sold the engine, trans, ecu, rims for $600.
And I bought a plow truck. Turbo diesel BITCH! 19psi, 17:1 compression.
http://i44.photobucket.com/albums/f2...e/DSC00661.jpg
Thanks, I think so too.
