#1 |
Hi guys again. Been a long time since i posted
![]() but here is an update on my Supra and some Pictures from my build up :P Mod list Boost logic 71mm GTS .81 A/R Single Turbo kit SUS321 Tig Welded Tubular Header HKS 50mm SS Wastegate 4” Stainless Steel Downpipe 4” Stainless Steel Midpipe 4” Aluminum Intake Pipe with Anti-Heat Coating 4" Boost Logic Polished Exhaust 4" AEM Dry Flow Air Filter PHR Stage 2 Complete Fuel System PHR 17.5mm ID high flow fuel rail upgrade -6AN Stainless Steel braided fuel lines liquid-filled fuel pressure gauge Siemens 850cc fuel injectors Dual Walbro fuel pumps Aeromotive EFI fuel pressure regulator) AEM EMS (Engine Management System) AEM Map Sensor - 3.5 bar Greddy 3-Row Front Mount Intercooler Kit Crower Springs and Retainers Set HKS Camshafts 264 Duration HKS DLI-2 Twin Power Ignition Amplifier PLX Devices R-500 Wide Band Kit HKS Racing Blow-Off Valve Type 2 HKS EVC 5 - KPA Measurement (Electronic Boostcontroller) Fidanza racing lightened Flywheel Stage 3 Pro Clutch Boost Logic Crank Pulley NGK Model 3330 Spark Plugs ARP Head Studs Titan Motorsports 2JZ Cam Gears Cusco Strut bars Blitz Dual turbotimer ![]() ![]() ![]() ![]() ![]()
Toyota Supra TT ?96 ![]() BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map |
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Did they make an original single turbo supra (1994)? | ts1994 | MKIV Supra | 3 | 07-20-2006 08:18 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
