#11 |
I have been rock crawling and 4wheeling for 16 years and I have only seen a handfull of incidents where items got in there and only 1 caused any problems. In a street driven car I dont see any real problem with it missing, I would say just search the forums and possibly Ebay.
89 Turbo 5 Speed hard top 1971 240 Z, 7MGTE, 5 speed, 487 RWHP @ 23 PSI, weighing 2505 lbs. www.ArizonaPerformance.com |
#12 | |
![]() Quote:
well that sounds better to me. i was thinking i could do real damage to the flywheel ect. |
#13 |
I would keep an eye out for one but it wouldnt keep me from driving my car. It would really take something big and solid to get in there and do any real dammage.
#14 | |
![]() Quote:
when i start going from park, my hole engine shacks and gets close to stall, if i even start with a higher rpm, and put it into gear slow "just so i dont take off to fast" the hole car still shacks.. HELP!! |
#15 |
Your clutch and light flywheel have everything to do with that. Does it seem much better when the car is stone cold? If so its probably the clutch and flywheel.
#16 |
#17 |
Nope thats just the way it goes. Make sure your diff bolts are tight so you dont break your rear subframe
#18 |
arz do you have a sports clutch? if so how do you control this hard take off. it feels like the only way i can take off is just drop it in gear.
#19 |
Mine is in the Z car it weighs 2505 lbs and really does well when its cold I have a sprung hub and got all the stuff from Aaron at Driftmotion. I dont think you can compare because my car weighs more than 1000 pounds less than a MKIII.
#20 |
save the money from a crank and invest in mhg with arp head studs. you can then do a few oil mods to help with that pressure, starting with an aftermarket gauge.
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
