Old 05-08-2007, 02:01 AM   #1
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
Default Supra Iceland Single T 71mm 2 videos - 2step and Dyno
here are two videos of my Supra
2step video building 17 psi boost but need better tires this was just on street tires and just doing it for fun some flames out off the wastegate and exhaust
http://www.youtube.com/watch?v=jc9TLxrvXw0
and here is a dyno that we did for fun. Car pretty much untuned on low boost pump gas with no fans in front off the car on a old dyno but still managed to dyno 520 hp 4th gear pull
http://www.youtube.com/watch?v=EOfsgXsBL44
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
Old 05-10-2007, 08:53 PM   #2
SupraTT/Iceland
here is a mod list
Engine
BL71mm GTS 0.81 A/R Single Turbo
SUS321 Tig Welded Tubular Header
HKS 50mm SS Wastegate
4” Stainless Steel Downpipe
4” Stainless Steel Midpipe
4” Aluminum Intake Pipe with Anti-Heat Coating
4" Boost Logic Polished Exhaust
4" AEM Dry Flow Air Filter
PHR Stage 2 Complete Fuel System
PHR 17.5mm ID high flow fuel rail upgrade
-6AN Stainless Steel braided fuel lines
liquid-filled fuel pressure gauge
Siemens 850cc fuel injectors
Dual Walbro fuel pumps
Aeromotive EFI fuel pressure regulator)
HKS 264 Cams
Crower Springs and Retainers
Boost Logic Crank Pulley
HKS Racing Blow-Off Valve Type 2
Titan Motorsports Cam Gears
Greddy 3-Row FMIC
ARP Head Studs
Powerhouse Racing Polished Upper Radiator Pipe Kit(Red Silicone)
NGK Model 3330 Spark Plugs
Transmission
V160 6speed Getrag
RPS Stage 3 with 6-puck Sprung Hub Disc
Fidanza Flywheel
Electronics
AEM EMS(Engine Management System)
AEM Map Sensor - 3.5 bar
HKS DLI-2 Twin Power Ignition Amplifier
HKS EVC 5 - KPA Measurement (Electronic Boostcontroller)
PLX Devices R-500 Wide Band Kit
Blitz Dual turbotimer
AutoMeter 52mm Boost Gauge
Chassis
18" Antera Wheels
Lowering Springs
Cusco front and Rear Strut Bars
Old 05-11-2007, 04:31 AM   #3
Supra2NR
Supra2NR's Avatar
love the 2-step video
what happend to the blue mk3 of urs?
Old 05-11-2007, 06:19 PM   #4
SupraTT/Iceland
hmm i?ve never owned a mk3 Supra
Old 05-12-2007, 11:40 AM   #5
Supra2NR
Supra2NR's Avatar
Default nevermind
i believe there was sumbody with iceland on the name too
that posted a mk3 with the front end conversion
oww, i lookd it was finland
sorry for the confusion bro
but i love the car, do you have any problems hooking up on the line
especially on the streets
cuz i dont see many street-driven rwd cars with two step
Old 05-20-2007, 04:16 AM   #6
SupraTT/Iceland
well i don?t usally use the 2step on the street because i only have normal street tires on the car 275/35ZR18
it?s pretty hard to get any traction on normal street tires but i just ordered some BFG drag radials. I?ll see if i?ll get them to hook. But i don?t think they will hook very well when i turn the boost up to 30 psi on C16 race gas and hopefully have about 720-820 rwhp
