Old 09-06-2007, 09:31 PM   #1
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
Default The Supra I Rebuilt
my name is travis and this is the supra i rebuilt
AND THIS IS WHAT YOU CALL A BAD ROD KNOCK
THATS WHAT A BEARING SHOULD LOOK LIKE ON TOP AND THE ONE ON THE BOTTOM IS WHAT I TOOK OUT FROM UNDER NUMBER ONE PISTON. I REPLACED THE ENGINE WITH A WHOLE NEW JDM 7MGTE,
This supra is now almost 100% complete ready to be sold. if i decide to sell it
and then i bought this car to fix all the parts i needed on the silver one
tsupra89 is offline   Reply With Quote
Old 10-22-2007, 06:14 PM   #2
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
looks good how much do you plan to sell for?
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 10-24-2007, 07:03 PM   #3
tsupra89
tsupra89's Avatar
i want to sell the silver one, the red one, and the engine together that i have i have a total of three engines for the supra, one 7mgte that has been tooken apart because of a rod knock the block needs to be bored, new crank or turned, new camshaft and new rods and bearings, the second one came in the red one with 70,000 miles on it but its been sitting so it needs new seals and piston rings, and the third one is in the silver one and is running like no other(immaculant) and i want to sell all them together for 4600 0b0. the lowest ill go on it is 4000 i have put 4300 into the car. and im doing lower ball joints new brakes and rotors and so it will go up to 4500 on what ive spent.
thew silver one has a two tone paint job on it now that i recently did myself. silver body and black stripe on the side, blacked out rims, koki style tail lights which is the standard just the middle piece painted black. and now i have some more stuff in mind im gonna replace the vavle covers with the ones ive painted black and silver and i am also gonna get a new 3000 pipe which will increase my hp by a little but look awhole lot better. it has a walboro fuel pump, areomotive fuel pressure regulator, lexus afm, k&n setup short ram, and alittle more stuff that i forgot but yeah thats it
Old 10-24-2007, 08:17 PM   #4
j3pz
nice work on it,feels good when you do your own work huh? not really diggin the pvc ic pipes but its prolly better then stock. gl with the sale
Old 10-26-2007, 08:14 PM   #5
tsupra89
tsupra89's Avatar
thanx but i dont dig the pvc either thats what the douchebag had on it when i got it im just using it because i have no money to get another one lol. but thanx agian and it feel real dam good to do your own work on a car
Old 11-08-2007, 02:24 AM   #6
tsupra89
tsupra89's Avatar
Default addition to what i rebuilt
this is what i have done to the supra in the last 2 months i have very more stuff in store for the supra including 5 speed swap, boost controller, turbo timer, new seals, hks hg and arp hb's, real main, front main, front cam seal, stage 3 weight reduction, and very more underhood parts, like pistons cam gears cams turbo and more. let me know what you think ill keep adding more
Old 11-15-2007, 06:13 AM   #7
4ageBT
4ageBT's Avatar
4ageBT is on a distinguished road
nice ride
Vw MufflerAcura Exhaust SystemBuick Exhaust System
Autoparwarehouse blog..
4ageBT is offline   Reply With Quote
Old 11-16-2007, 03:44 AM   #8
tsupra89
tsupra89's Avatar
thank you..............................
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
Old 11-16-2007, 05:47 AM   #9
Renegade89
Renegade89 is on a distinguished road
Originally Posted by 4ageBT
nice ride
qft, my dad used to have one similar nice work
Renegade89 is offline   Reply With Quote
Old 11-25-2007, 01:29 AM   #10
Spudboy
Spudboy's Avatar
Nice job.
Off topic but I wonder if anybody can tell me the best way to wire in a Blitz boost controller? Should I wire directly to the battery or somehow to the ignition. If the ignition how or somewhere else...how?
