#1 |
Has any one replaced the bushings on/for the #2 Lower Suspension Arm???
Its the square shaped one coming from the differential mount, over to the rear axle carrier/ hub. The inner end has an alignment adjustment on it. I want to replace the bushings (worn out), and I can use a press to get the inner one (TSRM page RA-63 #2) out/on because its in the arm. http://www.cygnusx1.net/supra/librar.../ra/RA_63.html But..the outer bushing is on the axle carrier/ hub. I don't want to remove the carrier/hub from the car, just to do this bushing. Has anyone done it on the car??? I don't know how to post photos or diagrams here, but it is on page RA-6, center of the online TSRM. And page RA-61 (item #4) http://www.cygnusx1.net/supra/librar.../ra/RA_06.html http://www.cygnusx1.net/supra/librar.../ra/RA_61.html Dealer wholesale cost, by the way, is $30 US ea bushing. Last edited by mrnickleye; 09-30-2005 at 02:41 AM. |
rear suspension problems | bena380 | MKIV Supra | 4 | 04-23-2011 03:16 AM |
MkIII Supra Pickup Drift Project | MARKPRIOR | Drifting | 23 | 10-01-2009 02:55 AM |
Wilwood MKIII Rear brake kit | ARZ | Arizona Performance | 0 | 03-16-2007 07:46 AM |
have some questions about 86-92 supra suspension | jeremy_e87 | Non-Generation Specific Questions | 2 | 01-10-2007 11:53 PM |
