Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 02-06-2005, 12:12 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
jumper with a piece of wire t & e1 in diag box in the engine bay, jump in car, turn key to ign and count the codes from engine check light
example code
21
flash flash... flash
34
flash flash flash... flash flash flash flash
2 codes stored
14 & 52
flash...flash flash flash flash............. flash flash flash flash flash... flash flash
now go here and find out what your code means
http://www.cygnusx1.net/supra/library/TSRM.../fi/FI_026.html
Pics of my build.
Do a diagnostic first!
Old 04-11-2005, 02:34 PM   #2
monkihead
SP58GT
monkihead's Avatar
monkihead is on a distinguished road
B) ....hmm...flash flash... :P
....all you need is a small taste of success and you will find it suits you....
monique- better off dead
monkihead is offline   Reply With Quote
Old 04-19-2005, 05:07 PM   #3
das
das is on a distinguished road
just thought i'd run a check out of interest and now have a quick question.
I have 4 positions on my ignition key, they are in order. Lock,Acc,On,Start
When i try the check in lock or acc i get no flashing lights, when it goes to start the light blinks constantly, what am i doing wrong ? lol
Hopefully i should only be in ACC position and there are no faults lol
das is offline   Reply With Quote
Old 04-20-2005, 11:19 AM   #4
suprra_girl
7M POWAH! ;)
your ignition should be set to the "on" position
if it blinks constantly or not at all
congratulations no faults present
Pics of my build.
Old 04-21-2005, 11:24 AM   #5
das
great, thats a relief, thanks suprra
Old 10-15-2005, 07:02 PM   #6
corewitz
corewitz is on a distinguished road
will just like a paper clip work? I tryed that and the engine light is just on always and never blinks. Also there is a lot of white gunk in the diag. box, would that have anything to do with it?
corewitz is offline   Reply With Quote
Old 10-17-2005, 12:20 PM   #7
suprra_girl
7M POWAH! ;)
yep... ppl have used paper clips
that white gunk is used to keep the terminals in good health i believe
Pics of my build.
Old 01-13-2006, 03:17 AM   #8
lifesnotfair
lifesnotfair is on a distinguished road
Default Great!
Thanks, supra girl. I have no idea what "t" and "e1" mean, but I will try to search for this tomorrow.
My hood shocks are "tired", so I hate to look under my hood coz I need one arm to keep it up, or a stick, which I never keep around =P
lifesnotfair is offline   Reply With Quote
Old 01-13-2006, 09:55 AM   #9
suprra_girl
7M POWAH! ;)
hehe good luck with ya codes
look in engine bay
locate fusebox
beside fusebox = another box with diagnostic written on it
inside diag box on lid you will see pin diagram
find T & E1 (also known as TE1 & E1) on the lid then match up with diag pins and put wire or paper clip into those to connect them together and walah... your cel will flash or do something
Pics of my build.
Old 01-18-2006, 05:21 AM   #10
CzA
CzA is on a distinguished road
Good stuff
CzA is offline   Reply With Quote
Did a diagnostic. redmaro MKIII Supra 5 02-04-2007 04:43 AM
diagnostic scanner sd88supra MKIII Supra 1 12-08-2006 03:38 AM
1995 Supra EGR Diagnostic??? johnlijo Non-Generation Specific Questions 1 02-26-2006 10:18 PM
