Old 08-03-2006, 09:58 PM   #1
inline6 turbo
inline6 turbo is on a distinguished road
Default 7mgte vs 1jz TT vs 2jz TT
right now my car is running the 7mgte motor but im planning on doing a motor swap...But im not sure what motor would be better im driving(well its in the shop gettin painted and re-aposterd) a 1989 targa top supra. Can anybody tell me which motor would be better for the swap and which one would gain me the most improve power in..the 1/4mile...0-60time and fastest accleration overall...thank you
car...1989 targo top super...white paint blue interior...stock..so far
inline6 turbo is offline   Reply With Quote
Old 08-05-2006, 06:43 AM   #2
Supra2NR
Supra2NR's Avatar
le me see where to start
ok
the 7mgte vs 1jzgte
almost the same identical engine except the 1jz has twins
you can achive this with the 7m also with the help of a custom downpipe
thier capabilities are almost the same
power is almost the same (not stock to stock of course)
but stock the 1jz has more power than the 7m
but once again it can be duplicated
7mgte vs 2jzgte
there is almost no comparison
2jz is the best engine that toyota ever made
power is no comparison
i dunt think the 2jz has the headgasket problem like the 7m (look that up)
all you need to do is port the head maybe oversized piston, and your good to go with the bolt-on power
but the big issue is the power:money ratio
the 2jz engine itself is expensive enough already
plus the only thing you can get is probly from an aristo
not the original 2jz's that came from supras
1jzgte vs 2jzgte
2jz all the way since it can handle more abuse than the 1jz
and the other stuff is above about this engines
my suggestion: see how much the 1jz conversion is gonna run you
then see how much to get a custom downpipe and other stuff so u can get a second turbo with your 7mgte
whatever is cheaper or easier go for that one
i did this researches online
this is to the best of my knowledge
cuz im also looking for a new engine
hope this helps you out
Old 08-06-2006, 07:18 AM   #3
inline6 turbo
thanx it helps alot. Ive looked online and seen a 1jz for 1900 and a 2jz for 2300 but im just mainly concern about the issue of labor cost and etc to swap and convert it....but i know dats the down side buh its a major upside cuz the 2jz does not have the headgasket problem....ive thougth about doing the twin set up on the 7mgte but then again...i dont think the gasket will hold even if i replace it and resurface it install a better one. but if i find out it works i would prolly do the conversion to the twin set up but righ now i prolly will go with a 2jz swap...cuz money come and money go
Old 08-06-2006, 08:42 PM   #4
Supra2NR
Supra2NR's Avatar
if by any chance you do this soon
can you sell me your 7mgte
im looking for an engine right now
and its hard to find
Old 08-06-2006, 09:06 PM   #5
newbsupra
newbsupra's Avatar
my friend can import a 1jz for around $1000cdn. i was thinking of the swap in my 87 7mge.. but there i need the new tranny and everything. what do you think? find a 89+ with a blown engine and swap it instead of doing a conversion?
Old 08-08-2006, 12:40 AM   #6
inline6 turbo
well is ur 87 in good condition already if so i would stay with the 87 buh i think the 89+ is better i know a supra fanatic dats has a 1jz in his 91 or was it 92 supra with a custom Intercooler and hes frame holds the power hes pushing aorund 350 and his bro has a 92 supra with a 2jz motor pushing 500 and they have no problem with the body at all so i say to go with the 89+ unless u love ur 87...and or get a good 89+ and sell the motor and use that cash to help pay for the 1jz swap....hope that helps and doesnt confuse you
Old 08-08-2006, 02:22 AM   #7
j3pz
if money is tight i wouldnt even think of a motor swap. but if money aint a problem then ok. the thing with the 1jz is the limited aftermarket support, its hard to find parts out there. if you got money falling outa your pockets, you got a shop you can take it too, and you have alot of experience working on motors and such then the 2jz would be what you want, but if you got money to throw around im sure you wouldnt be fiddleing with a mkiii. point is i would suggest sticking to the 7m
Old 08-08-2006, 04:57 AM   #8
Supra2NR
Supra2NR's Avatar
thats true
the 7m and the 1jz
are almost close to each other
that the conversion wont even be that much
2jz is the way to go (if you have money)
if not stick with the 7m
its not a bad engine
only the headgasket
but inline6 doesnt stink
Old 08-08-2006, 01:26 PM   #9
kwnate
SP58GT
My 7m-gte just laid down 667rwhp and 591tq. It's not stock though...
Nate
Old 08-08-2006, 03:52 PM   #10
Supra2NR
Supra2NR's Avatar
thats cold
why dont list sum of the mods that you got
so the rest of us will get an idea what we need to do?
when your running high horses like that,
did you get a mhg?(assuming you did already)
but does it still blow?
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
