Old 05-30-2007, 12:27 AM   #1
Kuban
Kuban is on a distinguished road
Default Rebuilding my ct-26
SOOOO iv taken in upon myself to rebuild my ct-26. So far iv gotten the compressor housing off, and the exhaust housing off as well. basically it looks like this
http://www.alltrac.net/images/turbo/rebuild4.jpg
Question though; on the ct-26 rebuild website it mentions pulling off the compressor nut. It says its a 10mm, and i can tell you its no 10mm. it looks to be something like a 18pt or 24pt nut. Anyone give me guidence here?
Also if the turbo im rebuilding is a upgraded .50 trim t3/t04e ct-26, can i still buy a standard ct-26 rebuild?
And i know i have to get the shaft balenced so dont try and tell me i dont know what im doing.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Old 05-30-2007, 02:21 PM   #2
supradaddy0803
supradaddy0803's Avatar
supradaddy0803 is on a distinguished road
I used to be a jet engine mechanic for a living. I would say that for the rebuild kit if it includes a new compressor wheel then your trimmed compressor wheel would have to be saved or get the new one trimmed as well. As for the nut I dont think they make a 18pt or 24pt socket or nut but it might be 12pt. Jet engines are a lot like turbos in a sense and they use a ton of 12pt nuts everywhere. Easier to torque and that kind of stuff. Go to sears and get a set of metric 12pt sockets. If they dont fit may be a SAE never know they are funny sometimes.
1987 supra NA 5 speed
1JZGTE swap
Tokico Illumina 2 and Eibach springs
Tokico pillow blocks
Suspension Techniques front and rear sway bar
HKS super dragger cat-back exhaust plus test pipe
Greddy Profec B spec 2 boost controller
HKS type 1 turbo timer
Supra sport solid steel drive shaft
Walboro 255 fuel pump
JZA70 Front end mod
18" Volk Racing AV3 18x8.5 front 18x9.5 rear
supradaddy0803 is offline   Reply With Quote
Old 05-30-2007, 04:53 PM   #3
Kuban
thx for the reply. I can tell you for sure its not a 12pt on the compressor wheel. The exhaust turbine is a 12pt 15mm. But the compressor nut has waaay more pt's on it than 12. Im pretty sure someone mentioned it could be an SST from toyo. Although they also said this is what the original nut would be like, not a trimmed up wheel nut. Maybe they resused the original, if they did there goddamn retarded.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 05-30-2007, 05:25 PM   #4
supradaddy0803
I looked in the tsrm and found a tool for that it is in the one listed on this forum not good at linking. As for that I called the toyo house and it is a expensive tool from what they say. If you lived close my friend actually has one he would let you borrow. From what he said you have to replace that nut becuase he thinks it is self locking and has that bent top to lock it. He said it was a 18pt socket that is part of the T handle that it comes on. At least when you do the rebuild you know who did the work and you know that it was done right.
1JZGTE swap
JZA70 Front end mod
Old 05-30-2007, 07:10 PM   #5
joebuffalo
joebuffalo is on a distinguished road
I am also in the process of rebuilding my CT26. The nut you are refering to can be taken off with a 3/8 socket. You just have to tap it on there lightly. My turbo rebuild kit came with a new nut. Here is a link to a website that has some great pictures that may be of some help.
http://www.mybluemr2.co.uk/CT26/index.htm
He is the one that suggests the 3/8 socket
joebuffalo is offline   Reply With Quote
Old 05-30-2007, 08:40 PM   #6
Kuban
ok thanks man that will help.
only one question left then, can i use a regular ct-26 rebuild kit with my turbo? even though its a t3/t04e .50 trim ct-26. Im assuming yes.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Rebuilding a turbo 90supra Non-Generation Specific Questions 1 04-28-2008 12:30 PM
Rebuilding a 1993 mkiv TurboTom MKIV Supra 1 01-29-2008 05:50 AM
Rebuilding turbo redmaro MKIII Supra 5 09-29-2006 11:05 AM
Rebuilding problems (7M-GE) Matt'sMKIII MKIII Supra 3 05-09-2006 05:03 PM
Rebuilding 87 7m-gte Reeves MKIII Supra 6 04-25-2006 01:10 AM
