Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 01-01-2007, 10:24 PM   #31
89whitedevil
89whitedevil is on a distinguished road
Default wow supra girl!!!
hey im impressed you really do you homework i think your the first person i have seen in a while that has this much info on this old of a car (i am a mechanic as my profession) and i work on brand new cars there much less complex than the older import cars it is hard to find info on alot of this stuff like codes wiring schematics ect. but just for info sake i have acsess to all of that so if anyone need this info let me know i also have diagnoistic procedures too i can post them really easily....
89whitedevil is offline   Reply With Quote
Old 03-31-2007, 12:10 AM   #32
dannydavi
dannydavi's Avatar
hey first off i really wanted to say this is an awesome technique, thanks for sharing. Second i got an error code 14: which is with ignition signal, diagnosis is no IGF signal to ECU... then it says "A" 7M-GE 6-8 which i dont understand, trouble area: ignition and ignition coil circuit, igniter and ignition coil, ECU. I also got trouble code 21: which is either oxygen sensor signal or oxygen sensor heater signal, So basically what im asking is can someone help me understand my trouble codes, and perhaps lead me in the right direction to eliminate my trouble codes, thank you.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-10-2007, 09:22 AM   #33
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
Default Computerised Diagnostics
I wanted a fast car, one with heaps of ponies, I could'nt buy a 300zx, my brother in law has one. So I went one better, I got myself a 1989 3ltr turbo supra (completely stock, still has original air filter). Made him envious, as you can well imagine.
To get to the point, I'm wanting to bridge my laptop to the engine management (diagnostics). Is this possible? If so where is the interface port (PLUG)?
linuxgurupodboy is offline   Reply With Quote
Old 05-28-2007, 10:03 PM   #34
supraboy380
supraboy380 is on a distinguished road
i tested my car and got codes 12 13 and 14, does anyone know how to fix them? i already looked them up, and i think its my throttle sensor but i don't know howto fix it. i think thats whats causing my car to cut-out at like 2500 rpm, but idk
supraboy380 is offline   Reply With Quote
Old 04-11-2009, 02:55 AM   #35
okinawasupra
okinawasupra is on a distinguished road
great info thanks!
okinawasupra is offline   Reply With Quote
Old 07-09-2009, 09:10 PM   #36
gfrererr13
gfrererr13 is on a distinguished road
Default Diagnostics
Will this work the same for a MKIV Supra as well? or is there anything different that needs to be done? Thanks!
gfrererr13 is offline   Reply With Quote
Old 09-09-2009, 09:13 PM   #37
red_armie_soviet
red_armie_soviet is on a distinguished road
I got 3 diff codes and they all seem to be electric, i got codes 24, 32, and 41, and im having a really hard time fixing them.
red_armie_soviet is offline   Reply With Quote
Old 01-07-2010, 12:32 AM   #38
I would like to know what years this works for as well, I know it works for all MKIII, I don't know about the MKII or MKIV.
Anyone?
Old 01-07-2010, 12:44 AM   #39
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
Typically will be the same for all toyotas 86-95ish
Some MK2's apparently have some sort of diagnosis system but I'm not sure which ones exactly, it's apparently a 2pin plug with a cap on it that you short.
Pics of my build.
Do a diagnostic first!
Old 12-05-2011, 02:55 PM   #40
90MarkIII
90MarkIII is on a distinguished road
Default MKIII trouble code 26
This is a great forum/thread! I read through the previous 4 pages and didnt see anything on code 26 on 1990 turbo supra, and this code is not in the manual. Just bought the car a month ago and have been restoring it to stock. Everything has been going well until it started intermittently started cutting of all power under heavy acceleration. It always havens from about 3000you rpm and up. Anyone ever had a problem with this code?
90MarkIII is offline   Reply With Quote
Did a diagnostic. redmaro MKIII Supra 5 02-04-2007 04:43 AM
diagnostic scanner sd88supra MKIII Supra 1 12-08-2006 03:38 AM
1995 Supra EGR Diagnostic??? johnlijo Non-Generation Specific Questions 1 02-26-2006 10:18 PM
