Yes, they tend to go bad. They are fairly cheap. I saw them on a website for under $30. I just forgot where the website was. Ill try to find it and post it up. Now if thats not ur problem, and you have a turbo and ur stock, oil is a common thing in the IC pipes and not something you should worry about unless its excessive. But if you think its a problem, just install a catch can.
