Originally Posted by djalkyd
i have a 7mgte and i am having a similar problem but only in 5th gear when i slam the throttle to the ground. it wont do it if i lightly get into it into boost then i can go all the way to the floor but if i snap it down from a cruise then it will buck and send a check engine light.
If it sends the check engine light, you've hit fuel cut.
