The oil pressure always stays relatively low compared to other cars. I think idle is around 6 and driving goes from 30 to 40. If its not reading at all, then ur oil pressure sending switch went bad. Ur knock sensor will go bad at some point and it will turn the check engine light on. Get the rewiring kit and rewire it and ur good to go. And the things circled in the picture are for ur headlights. If you take the rubber caps off and turn the red things left or right, ur headlights will go up and down manually. Very slowly I might add.
EDIT - I forgot to answer the last one lol, it sounds like a slight boost leak.
