Old 02-01-2007, 08:42 PM   #2
dcrusupra
dcrusupra's Avatar
Vacuum leak. Find the hose thats leaking and replace it. You can do this by running ur fingers along the hoses and if the hissing gets softer or stops you have found the hose that is leaking. Check the intake hose first, thats usually what cracks and makes the car idle like crap. If everything is fine, check to make sure all connections and clamps are tight.
New Rebuild
My CarDomain
