Originally Posted by supraman121
a higher amp fuse should'nt catch the car on "fire" or melt the curicet board the wiper with simply not work...
The fuse is there to keep too much current from going thru the wiring. A safety net. When it hits over the peak amperage the fuse blows thus saving your wiring. If you put in a higher amperage fuse it lets more current go thru the wiring which may cause a fire. Remember the wiring on the car is a very thin gauge wire. It doesn't take that much to heat them up.
