I only cut 1 pipe. Well 2, but I didn't use one of them. I cut the 140* pipe so it'll come off of the 3000 pipe and go the direction I needed it to. The intercooler pipes were a bitch to get on. I ended up using some of the rubber sections and the metal 90* piece from the stock intercooler pipes. So there is some restricted flow in my setup. But that's of no concern to me now, lol. If you are using the stock intercooler you need to get reducers. Whatever the piping size is down to 2". You'll need a reducer for the turbo as that is 2" also. And the 3000 pipe is 2.25" so you might need a reducer for that one.
