The cable is stretched. It's common with the gas and trunk lever. You'll need to pull out the drivers seat and pull up the carpet on that side. You may not need to take out the drivers seat but I'm sure it will make it much easier. It's only 4 bolts and 2 connectors. But it's heavy as hell. Unhook it at the trunk latch and just pull on the cord. That's the easy way.
