Old 05-18-2007, 05:45 AM   #10
dcrusupra
dcrusupra's Avatar
Originally Posted by Kuban
Oh? and yet toyota decided it was a good spot to store FUEL? Take a look under that engine bay once, then tell me where else it would go. Cusco and greddy both make mkiii supra kits that braket right to the strut tower, which is even closer to the turbo. So honestly i think its pretty safe.
Ok well i should have said it would be better (instead of need) to put it in a cooler spot in the engine bay. Simple science tells you that if the surrounding air is colder it'll allow more vapors to into the catch can as opposed to it being next to the turbo. You can mount the catch can pretty much anywhere if need be. Just because some companies make brackets for a certain spot doesn't mean that is the recommended place for it.
New Rebuild
My CarDomain
