Well if you've changed the spark plugs, that means you've taken off part of the intake. Its not hard getting the valve covers off. Just do the same like you were going to change the spark plugs. There are 6 screws that hold each valve cover on. Not much room to screw anything up until you start putting things back on and forget where things go. But there are millions of pictures out there of these engines.
The belts are pretty straight forward also. Theres one that goes around the power steering pump and crank pulley. One that goes around the a/c compressor and crank pulley. And one that goes around the alternator, fan, and crank pulley. Which ever one you need to replace, just loosen either the a/c compressor, power steering pump, or the alternator. Problem is they are in a line. I don't remember the order of them but it would be best to replace them all. Again, you wont have any trouble unless you don't remember which belt goes where on the crank pulley. But you'll get it because they wont fit right if one is in the wrong place.
