Before you drive the car again, get a block tester from your local auto parts store. Is it overheating? You DO NOT want to drive it if it's overheating. You'll start warping the head or maybe even the block. And if it's blown enough the coolant is getting into the oil and it could cause you to get rod knock. All you need is a VERY small amount of coolant to come in contact with the rod bearing and you'll get rod knock.
