#1 |
Hi. Now I know what needs to be done, but how to do it? I am trying to get the drivers side interior door panel off so I can replace the out side bumper molding. I tried unscrewing the obvious screws, but I get to a point where there is nothing more obvious.
Is there some sort of manual, diagram or instructions on how to do this that someone can email to me or direct me where to get it? Thanks, Stan |
#2 |
Did you take the 2 big screws out of the door pull? Those go right into the door itself. When all the screws are out, you have to undo the little clip behind the light. Then push up from the bottom. Not out, up.
Wiring diagram? | dannydavi | MKIII Supra | 3 | 04-07-2009 04:18 AM |
wiring diagram help! | shiftysupra | MKIII Supra | 2 | 11-09-2008 07:36 PM |
HLP - 87 fog light diagram | kaves_420 | Non-Generation Specific Questions | 1 | 10-28-2006 04:49 PM |
PLS HELP:87 moonroof wiring diagram | kaves_420 | Non-Generation Specific Questions | 2 | 10-26-2006 02:59 AM |
Vaccum diagram??? | h8z2luze | MKIII Supra | 5 | 08-11-2006 02:47 AM |
