Old 02-19-2007, 11:15 PM   #1
88Tsupra
88Tsupra is on a distinguished road
Default only grind when shifting to reverse
well as short as possible once in awhile when i put my car in reverser(manual) it grinds loud and nasty...and i do have trouble to put the car into n e gear sometimes i have to force it into gear...even wen the clutch is all the way down...ty
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 02-20-2007, 01:32 AM   #2
ddmcse
ddmcse's Avatar
Cool
when i run into this
i release and press the clutch one more time instead of forcing it
it happens the same in all 3 supras i've had and 2 toyota trucks
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 02-20-2007, 02:07 AM   #3
88Tsupra
thanx buh i dont force it in though. it goes in without a problem buh it just grinds..buh ima try that...n e thign will work
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 02-20-2007, 02:26 AM   #4
mr.w
mr.w is on a distinguished road
Yeah I have this problem too, I'll have to give that tip a shot.
mr.w is offline   Reply With Quote
Old 02-20-2007, 03:02 AM   #5
supraman121
mine does the samething the sycronizer (how ever you spell that) is out i find after the car has been running for a while it shifts into reverse without grinding just put it in reverse when you park it and you should have the problem or do as someone said above "double clutch it" and it might work too
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 02-20-2007, 03:16 AM   #6
OfnaRcR
OfnaRcR is on a distinguished road
Mine only grinds if i am rolling and i try to put it into reverse. It won't shift into reverse sometimes so i just roll a bit and then it goes in.
OfnaRcR is offline   Reply With Quote
Old 02-20-2007, 05:02 AM   #7
mrnickleye
mrnickleye's Avatar
I don't believe there is a syncro for reverse. So...you should always put the clutch in and wait a few seconds before attempting reverse gear.
Does it go right into first gear??
Sometimes, when they wear down, or other problems arise, the clutch disc may stick a little to the flywheel, or pressure plate.
That will also cause the problem you describe.
Also, perhaps the clutch is not fully dis-engaging when you press the pedal all the way in.
Old 02-20-2007, 04:03 PM   #8
dcrusupra
dcrusupra's Avatar
There is no synchro for reverse. So it's normal. Unless it takes a little more than just "some" forcing. Then there may be a bigger problem.
New Rebuild
My CarDomain
Old 02-20-2007, 06:24 PM   #9
88Tsupra
sometimes i have to almost man handle it into first gear buh sometimes it slides right in...buh for reverse i have to put it into every gear then itll go into reverse
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 02-20-2007, 06:50 PM   #10
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
sometimes mine wont go into reverse no matter how hard i push on the stick. i have to do one of two things, 1.let the clutch out a little bit while applying a little pressure to the stick and it slides right in or 2. take foot off the brake and let the car roll forward or backwards a couple inches and itll go in.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
shaking in reverse..at low revs??? cel Non-Generation Specific Questions 0 12-05-2008 06:38 PM
second gear grind tak2099 MKIII Supra 10 05-12-2008 03:32 AM
reverse probs? 89_supra_ MKIII Supra 1 12-14-2006 08:37 PM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
reverse glow gauges Stuba MKIII Supra 3 09-23-2005 01:18 PM
