Old 06-29-2008, 12:09 AM   #1
3.0trd
3.0trd is on a distinguished road
Default won't idle
89 na manual. will not idle. I've replaced the tps, and it fixed the high idle problem I was having, tried putting the old one back and didn't change anything. I can keep it running by raising the rpm, but on its own it just drops and dies. out of gear it idles rough while I hold it, but in gear it goes through the whole rpm band with no problems... fuses all fine, can't check the timing cause it won't idle, but it just passed emissions, and I don't think the timing belt jumped cause it runs just fine off idle
Cometic MHG, ARP studs, H&R lowering springs
3.0trd is offline   Reply With Quote
Old 06-29-2008, 12:48 AM   #2
3.0trd
ok, just tested the tps and iac(isc) all checked out fine, the car does seem to try to idle with the iac unplugged, it will stumble once or twice, with it plugged in, it just drops instantly after you let off the gas.
Old 06-29-2008, 01:16 AM   #3
3.0trd
checked the codes, I've got 41 (haven't cleared after replacing tps) and 24 which I believe is something to do with the knock sensor? would this not let the car idle?
Old 06-29-2008, 01:39 AM   #4
dcrusupra
dcrusupra's Avatar
Code 41 is a fault in the throttle position sensor signal.
Possible trouble points:
  • Throttle position sensor
  • Throttle position sensor circuit
  • ECU
Code 24 is a fault in the intake air temperature sensor.
  • Intake air temperature sensor circuit
  • ECU
New Rebuild
My CarDomain
Old 06-29-2008, 03:37 AM   #5
3.0trd
tested everything in the afm, all in spec
Old 06-29-2008, 04:12 AM   #6
3.0trd
ok, got some alligator clips and tested the operation of the isc. unless it is supposed to move a lot, I think it is frozen. when I ground the s terminals, the valve twitches but doesn't actually move...
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
HELP!!!!!!!.....1JZ wont idle!!!!! kuroi_tuki MKIII Supra 1 07-09-2007 12:41 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
