Old 03-23-2006, 06:11 PM   #1
87nasupra
87nasupra is on a distinguished road
Exclamation need help please hurry!!!
ok i have a problem my engine has coolant leaking in to the oil im worried this is becasue of a bad gasket does anyone know why this is happening and what i have to do so i can fix it and stop the coolent from leaking into the engine ( oil)
87nasupra is offline   Reply With Quote
Old 03-23-2006, 06:16 PM   #2
j3pz
this is ussually a sign of a bhg. get a compression test done, all 6 cylinders should read around 160psi (sound correct?).
Old 03-23-2006, 06:19 PM   #3
87nasupra
Default comp test
ok how do i go about getting a comp test done? and if it is infact a bhg wel that sucks
Old 03-23-2006, 07:00 PM   #4
dcrusupra
dcrusupra's Avatar
If you have white smoke coming out of the exhaust, it smells like coolant, and the oil in the oil cap is kind of milky, then its a BHG.
New Rebuild
My CarDomain
Old 03-23-2006, 07:05 PM   #5
87nasupra
ok thats the thing i dont have a bellowing white smoke ( seen that befor) and my oil itsnt milky per say it looks thinner and has a slight very slight greaan tint to it and here the kicker sometimes i can smell coolent from my air vents thats what i dont like abot the hole thing so im not to sure whats going on
Old 03-24-2006, 06:04 PM   #6
j3pz
a local mechanic should be able to perform one. heard they might charge like $15 or something, or you could buy a compression gage and all the due-hickies and do it yourself.
Turbo Elbow on Ebay: Inexpensive Hurry! Bullz_EyE MKIII Supra 0 11-06-2005 09:50 AM
