Old 03-26-2006, 02:40 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Head Bolt Retorquing
When replacing a BHG with a stock or Fel-Pro gasket, has anyone retorqued the bolts/nuts after a few heating/cooling cycles? Did they move at all? I want to determine if these non-metal gaskets crush down a bit after heating a few times.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 03-26-2006, 05:20 AM   #2
dcrusupra
dcrusupra's Avatar
It always good to retorque them after about 500 miles. And im hoping your not reusing the stock head bolts.....
New Rebuild
My CarDomain
Old 03-26-2006, 05:32 AM   #3
Benesesso
Benesesso's Avatar
>"And im hoping your not reusing the stock head bolts....."<
Bought a set of ARP bolts, not studs. Discovered that 10 of the 14 won't go into the head w/o grinding clearance into the bolt area. All 4 end bolts go in fine. So I used 4 of the ARP's and 10 stock bolts--all just torqued tonight to 72 ft. lb.
I really don't think the ARP bolts/studs solve anything. The stock bolts don't stretch (other than elastically just like the ARP's). The stock gasket crushes over time/heat and that's why the bolts get loose.
Anyone ever BREAK a stock bolt?
Old 03-27-2006, 02:30 AM   #4
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
yes i had my hg changed on my 87 when it had like 190,000 on it and the bolts were all broke, striped, and streched to shit.
87 N/A with a new JDM 7mge.
Looking for a 7mgte
Levi1717 is offline   Reply With Quote
Old 03-28-2006, 06:32 AM   #5
mrnickleye
mrnickleye's Avatar
Wink
^^ "I really ought to sell both Supras and get something else"
NO !! ......... hang in there !!
Old 03-28-2006, 11:38 AM   #6
ddmcse
ddmcse's Avatar
Cool
toyota really did "blow it" with this engine
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-29-2006, 08:42 AM   #7
1988gte
1988gte is on a distinguished road
wow i didnt know that, bad gaskets or lots of miles then? are studs better?
1988gte is offline   Reply With Quote
Old 03-30-2006, 02:57 AM   #8
ddmcse
ddmcse's Avatar
Cool
if you can do the studs do them instead of bolts .
be warned that when studs are on the head wil be a monster to get back on if the block is still in the engine
My Supra KiXGaS
Old 11-07-2006, 03:49 PM   #9
Isphius
Isphius's Avatar
very old thread...but do the arp studs go in while the head is on? or is it possible to get the head over the studs while the block is still in the car, if you put the studs in the block first? I just got my HG set and studs, so someone respond quick!
Need a 14mm allen head bolt for valve cover trevor217 MKIII Supra 4 10-30-2008 02:50 PM
are arp head stud same as bolt 88Tsupra Shops & Part Reviews 4 03-11-2007 02:43 AM
Head bolt torque kjhsupra Non-Generation Specific Questions 3 04-06-2006 09:19 AM
ARP head bolt torque Intenseneal MKIII Supra 2 08-31-2005 10:08 PM
head bolt specs skunk MKIII Supra 3 07-13-2005 07:29 PM
