Old 03-29-2006, 06:52 PM   #1
1988gte
1988gte is on a distinguished road
Default door sag
anybody know how to fix a sagging door
1988gte is offline   Reply With Quote
Old 03-29-2006, 09:47 PM   #2
dcrusupra
dcrusupra's Avatar
New hinges or put washers where the bolts are.
New Rebuild
My CarDomain
Old 03-30-2006, 08:32 AM   #3
1988gte
ah so bolt, washer, then put in door?
Old 03-30-2006, 08:42 AM   #4
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
I like to fix things the right way and be done with - I only see replacing the door hinges (if the problem is what I think it is).
I sold my driver's side hinges (left side) to a guy that had that problem.
I can't tell you how well it would work to put spacers/washers in there, but I know that the way these doors open & close (at least mine) is a pretty precise operation.
Just get some new hinges, if it is what I think it is.
Are we talking about the driver's side?
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Old 03-30-2006, 03:33 PM   #5
1988gte
yes sir so do i give toyota a call?
Old 03-30-2006, 04:34 PM   #6
dcrusupra
dcrusupra's Avatar
Jay Marks Toyota.....
Upper Hinges
Lower Hinges
The hinge pin is usually trashed because of these massive doors. When you change them, take the fender off and leave the door closed. 1 hinge at a time. Much easier.
New Rebuild
My CarDomain
