What's the word on which NGK's to use in a turbo--platinum or the newer iridium?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein 1988 and 1990 Turbo Supras |
Iridium is better IMO
Iridium is better, and there are two types available. IF you go to Supra sport they sell both the difference is;
to quote Charles Britz of SupraSport.com "The difference is in the heat range. BCPR5EIX11 3306 is a hotter plug meaning that there is more electrode exposed. You can use this plug with basic performance upgrades but when turning up the boost the BCPR6EIX 5689 is a better choice because it is colder. With the higher temperatures with a turbo charged engine could cause the hotter plug to fail or cause preignition." |
Picked up a set of NGK Iridiums yesterday. $6.95 ea.
Spark Plugs (1G-GE vs 7M-GE) | makemedie | Non-Generation Specific Questions | 5 | 10-26-2008 05:19 AM |
NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
Issues After Changing Spark Plugs | Getphazed | MKIII Supra | 8 | 11-03-2006 12:31 PM |
Spark plugs & WIRES | HEMAN | MKIII Supra | 2 | 11-03-2006 05:31 AM |
