Old 04-10-2006, 04:17 AM   #1
86MKIII
86MKIII's Avatar
86MKIII is on a distinguished road
Default LSD Non-Turbo?
I was just wondering if my 1986.5 Supra Non-Turbo has LSD or not. I wanna get one for it while i'm building it if not. I'm changing out the engines (with the 7MGTE) so I know i'll need it. thanks in advance.
86MKIII is offline   Reply With Quote
Old 04-10-2006, 04:58 AM   #2
dcrusupra
dcrusupra's Avatar
If it drives, then just peel out. If it leaves marks on both sides than it is.<---The fun way...If it doesnt drive then put it on stands and turn one wheel. If they turn opposite ways its not an LSD.
New Rebuild
My CarDomain
Old 04-10-2006, 07:16 AM   #3
SCRAMJET
SCRAMJET's Avatar
In your engine bay on your compliance plate, there will be a part saying TRANS/AXLE. The first part stamped after that should read W58 which is the code for the standard NA transmission. The second code written there is the code for your diff. It is my understanding that if the number in the code for the axel is an odd number, it is an LSD diff. Mine was G285 which means it's an LSD diff. Mine used to be a non turbo also so you might be lucky and have one too.
Old 04-12-2006, 02:16 AM   #4
Dejvid1785
Dejvid1785 is on a distinguished road
The last number in the axel code should be 3 or 5, if it is one of those it has an LSD rear end.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 04-12-2006, 12:47 PM   #5
Isphius
Isphius's Avatar
will the lsd diff fit inside stock read end, and do they have different gear ratios?
Old 04-13-2006, 12:53 AM   #6
Burn N' Up
Burn N' Up's Avatar
Or you could just look at the Differential, they have a large LSD in red pasted to the back.
