Old 05-05-2006, 08:34 AM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Crank pully removal
I just finished replaceing the head gasket, still nto sure how well it will do but i guess il see
In the process i saw my timming belt was warned and cracked so i got a replacement but it seams to eb harder to do all that stuff then i thought, Any sugestions oh hwo to remove it ?
I have the cams off so dont have to worrie about bending the valves (If i havent already)
I just need to remove the remove the crank pully so i can get the bottom cover offto remover the beltand what not
Any sugestions would be much apreciated (I know i probly spelt that wrong)
G-string is offline   Reply With Quote
Crank Shaft Pully Question kidsusukigsxr Non-Generation Specific Questions 1 04-15-2011 08:45 PM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Need help with front crank shaft pully bolt tmetal_blk Non-Generation Specific Questions 3 06-24-2007 06:24 PM
Crank Pully timming G-string MKIII Supra 2 05-25-2006 12:11 AM
