Old 06-12-2006, 08:14 PM   #1
Fkatz
Fkatz is on a distinguished road
Default 5spd conversion
sry im a noob and i've been searching for 3 days now
i am going to buy a 2jzgte and i want to put a 5 spd in it will the w58 bolt up and work with the motor or will it just bolt up i searched on the forum and it says bolt up but this does not necesarily mean that it works. so does it work is the input shaft or is it very different or can i buy the automatic and take the bellhousing off of it and put it on another supra 5 speed or not i am capable of the work just want to be 100percent b4 i start
thank you for your time your help is greatly appreciated
Fkatz is offline   Reply With Quote
Old 06-12-2006, 08:29 PM   #2
Supra2NR
Supra2NR's Avatar
there's a site where it said that the stock transmission for the car wont work when you go from n/a to turbo, but if i was you, if youre gonna spend some dough on a transmission, why dont you get a 6spd one since your getting a 2jz engine
that kind of engine only deserves a tougher and stronger transmission
cuz ur gonna have a hard time putting those horses into the ground with a 5 spd
Old 06-13-2006, 04:04 AM   #3
Fkatz
but will the turbo 5spd work cuz if you buy the 6pd it is used no warranty and when it goes out you have to buy another one for 6k the car will be for drag racing too so i don't want 6spd plus the gear ratio of the 5spd for the first gear is really good if i get into road racing then 6spd it is but price/availabilty/the strip all factor into what i want out of the supra thanks for the advice tho
Old 06-13-2006, 02:05 PM   #4
Supra2NR
Supra2NR's Avatar
there's a few diffrences from the stock turbo tranny and the stock n/a tranny
As far as transmission choices, you can reuse whatever trans your NA had. The W58 (NA 5 speed) will bolt up to the 7MGTE w/no problems. The NA auto trans is basically the same as the turbo auto trans, just some subtle differences inthe clutch packs, etc. to hold the extra power. If you do have an auto trans you might want to think about rebuilding it or replacing it w/a 5 speed as it will hold only about 300rwhp. The W58 should hold upwards of 400rwhp and the sky is the limit w/the R154.
here's a qoute from one site , i havent heard of anybody discussing 5 spds wit 2jz's so i guess the best i know is the r154 is the closest choice for your 5 spd
so hope this helps you
Old 06-13-2006, 02:45 PM   #5
dcrusupra
dcrusupra's Avatar
The 2jzge uses the W58 tranny. I'm not so sure u should use it for the 2jzgte engine.
New Rebuild
My CarDomain
Old 06-13-2006, 07:58 PM   #6
Supra2NR
Supra2NR's Avatar
whats the diffrence with the 2jzge and the 2jzgte
i thought when its says 2jz its automatically twin turbo
its there also a 1jzge and a 1jzgte?
im confused someone enlighten me
everytime i know sumthin something always comes up and gives me a quick cheapshot on the jaw
Old 06-14-2006, 03:37 AM   #7
dcrusupra
dcrusupra's Avatar
Big difference. 2jzge = nonturbo. 2jzgTe = twin turbo
Pretty much anything with a T in the engine code is turbo.
There are also 1jzge's and gtes. I think some of the Toyota Soarers (Lexus SC300) from Japan came with the nonturbo 1jzs.
New Rebuild
My CarDomain
Old 06-14-2006, 04:20 AM   #8
Fkatz
thanks for the help where can i buy a r154 5spd what model does it come from i got a qoute for a 2jzgte w/turbos and auto ecu for 2000 he said the ecu is for auto but works w/manual too is this a good price or anyone no cheaper thanks for the help
Old 06-14-2006, 07:44 AM   #9
Isphius
Isphius's Avatar
Transmission question...How long will the stock auto in an 89 turbo last before it needs replacing, With just a few mods, Filter, IC pipes, maybe a new IC or not, And full exhaust. and thats about it. Is there any perforance trans rebuild kits for the autos? Im sure someone has to make one...
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
5spd conversion tokis MKIII Supra 3 11-25-2007 03:26 AM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
celica supra engin conversion supramadness MKII Supra 3 04-10-2006 12:00 AM
5spd conversion wiring 87 supra? anyone know? supramang Non-Generation Specific Questions 0 12-01-2005 12:25 AM
