#1 |
I have and 87 supra turbo which is runing like crap right now and i need some help. This is what happens when im driving ill get out of first then if i try and go a little faster and my car jerks and dont really go anywhere till i get boost witch is about 3000 RPM then it runs ok but when ever its under stress it just starts jerking its bin like this since i bought it. what could be my problem. i also just hallowed out my cat on the down pipe becausse it was clooged i also found out that my downpipe only has 2 of the 3 nuts and where it connects from the main cat it only has 1 bolt. is it because theres not enough back pressure or off timing i have no clue and i need help. What could it be. =[
PS Anyone on these forums live in Fall River, MA??? Last edited by Sharaz508; 06-15-2006 at 01:46 AM. |
Having some Troubles... | 87MGE | MKIII Supra | 4 | 05-03-2008 08:03 AM |
Knock Sensor Troubles!!!! | Draftinwitjr3815 | Non-Generation Specific Questions | 0 | 03-18-2008 10:16 PM |
engine troubles | yota_head | MKIII Supra | 4 | 02-21-2007 05:58 AM |
map ecu troubles | turbotaco | MKIII Supra | 2 | 01-03-2006 07:41 PM |
smog troubles | tonster | MKII Supra | 2 | 09-24-2005 10:21 PM |
