#1 |
I think my car some some electrical problem. To start, my gauge lights never come on (yes I checked the dimer) also when I turn on my head lights, my time light dims and the controls for the AC/ heat go off. I checked and changed the fuses but the previous owner had a 15 amp fuse for the gauges and it is only suppose to be a 7.5 amp fuse... not too sure if that could have caused the dash lights to die completly or what.
![]() I found I need a new head gasket, was just wondering how much it would cost for a new one. Turbo is gimped, burns oil and the fins inside are chipped. Anyone have a good / decent (better or equal to the stock one)? It needs a new strut on the passenger side, anyone know what that might cost? Also the power steering leakes a lot of fluid. But I must say, after owning it for only 3 days so far, it is one fun car that likes to go really fast. ![]() |
#2 |
Now that I have been checking around for prices on a head gasket, I was wondering if I need just the head gasket or the "head gasket kit", not really sure what the difference is except the kit is around $100+ more
#3 |
SP58GT
Get the kit, everything you pull off has gaskets. Replace any old gasket you remove with a new one.
Nate ![]() ![]() |
#4 |
It might be the dimmer switch itself. If that gets fried, the lights wont work anymore. So get a new dimmer switch from the local yard and put it in.
problems problems problems.... | 86SupraMan | MKIII Supra | 5 | 02-04-2008 04:28 PM |
Starting problems and accleration problems! | alekjame22 | MKIII Supra | 6 | 03-17-2007 11:19 PM |
89 supra. lots of problems.. HELP!! | 89_supra_ | MKIII Supra | 9 | 12-15-2006 02:28 AM |
problems, problems, and problems | tone loc | MKIII Supra | 6 | 09-06-2006 04:35 AM |
New Supra...lots of little problems. | TxSpeedBoy | Non-Generation Specific Questions | 12 | 02-07-2006 03:32 PM |
