Old 08-09-2006, 05:02 AM   #1
marc
Default yet another problem with the beast
ok well now the other day i was turning on my car and it delayed b4 starting. and since then everytime ive started it it's gotten worse. now it litteraly takes a minute of turning it on and off to start the car. u can here it clicking but it just doesnt start. my deduction...a bad starter? or solenoid? and for sum reason my bulb replacement light comes on but none of my lights are off..blown fuse maybe? any help would be aprreciated.
thanks ahead of time,
marc
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-09-2006, 11:31 AM   #2
f00g00
Either a weak battery or starter is drawing too many amps.
Old 08-09-2006, 10:53 PM   #3
dcrusupra
dcrusupra's Avatar
Check the fuses. But it sounds to me like a bad starter relay.
New Rebuild
My CarDomain
Old 08-10-2006, 12:33 AM   #4
supradaddy0803
supradaddy0803's Avatar
Default I had about the same problem
With my 86.5 I ended up having to replce the negetive battery terminal because it had the factory one on it and it looked alright but upon further investigation it was cracked and loose next to the bolt that tightnes it hold onto the cable and twist the cable a little to bring pressure onto the terminal and have someone try to start it if it starts right away replace the cable connector then try again if it starts acting up again replace the battery. I deal with DC electrical systems everyday it is usually a connection.
Old 08-10-2006, 04:59 AM   #5
marc
today there is suddenly no starting problem and same thing yesterday..it has mysteriously vanished...now the hole in my exhausts opened again. i never knew u culd love and hate a car so much. my turbo does sound NUTS with a hole in the exhaust tho. u can here the bov and here it spool up a lot better for sum reason.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
