Old 08-30-2006, 03:53 AM   #11
dcrusupra
dcrusupra's Avatar
Make sure the gap in the plugs are .44
New Rebuild
My CarDomain
Old 08-30-2006, 06:32 PM   #12
Burn N' Up
Burn N' Up's Avatar
If you have the TSRM use it to follow every vacuum line and make sure there are no cracks and they are all hooked up to the correct orrifice on each fitting, I had one switched around and blammo, ran like crap. Don't forget the ones under the intake plunem(SP?).
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Old 08-31-2006, 04:20 AM   #13
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Ok well I found a inch or so of water in my #2 cylinder so ya another bhg I must have ppinched it when I put the head on. Going with a metal HKS gasket this time. SOOOOO PISSED!
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 08-31-2006, 09:45 AM   #14
Supra2NR
Supra2NR's Avatar
calm down
look on the bright side
after this headgasket job with the hks one
it might be another while b4 you go back in there
Old 08-31-2006, 02:29 PM   #15
Ahmad88
Ahmad88 is on a distinguished road
i wouldnt let ur engine overheat for more then 20 seconds, mine overheated for about a min or a lil more. BAM head cracked.
Rollin in a 98, flippin 94's
Ahmad88 is offline   Reply With Quote
Old 09-01-2006, 03:26 AM   #16
h8z2luze
h8z2luze's Avatar
I think I might have my head checked again cause it was burried in the H for almost a minute. I hope its ok.
Old 09-01-2006, 03:47 AM   #17
h8z2luze
h8z2luze's Avatar
Ok 2 questions can I use my ARP headbolts again and What size of the HKS metal head gasket should I get? Would I be ok with just the 1.2mm or should I spend a ridiculous $100 more dollars and get the 2.0mm?
Old 09-01-2006, 04:20 AM   #18
dcrusupra
dcrusupra's Avatar
The headgasket is supposed to make up for the MMs they shaved off the block/head which is absolutely necessary for a MHG. They need to machine and lap the block and head, making it perfectly smooth.
New Rebuild
My CarDomain
Old 09-01-2006, 03:54 PM   #19
h8z2luze
h8z2luze's Avatar
Ok wait so I have to have the block machined too?
Old 09-01-2006, 06:19 PM   #20
SupraSaver87
SupraSaver87's Avatar
SupraSaver87 is on a distinguished road
Cool Welcome To my world
Cars....you can't KEEP them in your garage, but if you take them out, all they do is cost you money.
Well I found out yesterday that I have a BHG as well....YAY! But the whole proccess of shaving the block, and all that, plus buying the MHG, and getting everything pollished...should be under $1,000 CND.
Just remember...while the engine is apart...its a great time to do other things...even just checking the hoses for leaks, making sure everything is shiney and do anything else you can think of...because when an engine is out, its EASY as anything to work on it.
My Ride: http://www.cardomain.com/ride/2351563
Our Supra’s, which art in the driveway,
Hollowed be thy power, thy mods are great, thy speed endless,
On the road or at the track. Give us this day free of cops,
And forgive us our impound charges, as we forgive those who are slow.
And lead us not into speed traps, and deliver us from the interceptors,
For thine is our car, the power, and the glory…forever and ever….amen.
SupraSaver87 is offline   Reply With Quote
just a little venting about transport companies KingDiamond Off Topic Forum 1 05-26-2005 05:49 AM
