Old 09-21-2006, 03:19 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default 1jz??????
Does anybody what kind of transmission is used with the 1jz and what kind of turbos that engine has. I was also told that the 1jz gives you less issues with overheating than the 7m-gte. Has anyone done a 1jz swap into a NA body?
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 09-21-2006, 04:20 PM   #2
Isphius
Isphius's Avatar
Dont quote me on this, but i think the 1jz comes with the same r154 as the 7m, and a slightly tougher automatic. Someone correct me if im wrong. And overall it is a better stock motor than the 7m, But i beieve the 7m has a lot more parts available and is a lot cheaper. It is also 3 liters instead of 2.5 so you have a little more torque and power cause of that once there both modded. But the 1jz is supposed to not have any headgasket problems like the 7m, But i would still upgrade it anyway, as with any high boost motor.
Old 09-21-2006, 04:56 PM   #3
Supra2NR
Supra2NR's Avatar
theyre almost identical engines
except for the fact that the 1jz came with twins
and i dont think it has the headgasket problem
but with the 1jz the aftermarket/part support isnt as strong as for the 7m
but when it all comes down to it, i think it depends on a person's preference
Old 09-21-2006, 11:06 PM   #4
kwnate
SP58GT
It uses the same 5 speed (r-154) with a different bellhousing.
Nate
Old 09-21-2006, 11:13 PM   #5
dcrusupra
dcrusupra's Avatar
Manual trans is an R154 like Nate and ISPHIUS said, and the auto tranny is the A340. The turbos are the CT12a.
New Rebuild
My CarDomain
Old 09-22-2006, 02:07 AM   #6
Isphius
Isphius's Avatar
weezl didnt say anything! lol. And there not really identical...None of the parts are interchangeable and they dont even look the same lol. But there both straight 6 toyotas....thats the good part
Old 09-22-2006, 02:26 AM   #7
Dejvid1785
So they pretty much use the same drive shaft as the turbo supra since it is the same tranny. How hard is it to swap it over to an NA supra? Has anyone done it? Some guy at NOPI did it but it was a turbo supra to begin with. He told me it was pretty much plug n play is this true?
Old 09-22-2006, 02:55 AM   #8
dcrusupra
dcrusupra's Avatar
O, haha. I was in a rush. Sorry. I edited the post. Lol. Gotta give credit where its due.
New Rebuild
My CarDomain
Old 09-23-2006, 03:20 PM   #9
SCRAMJET
SCRAMJET's Avatar
I've jammed one in an NA 1986.5. It is pretty much plug and play, except for the fact you need to change the front crossmember to suit the ijz.
Old 09-23-2006, 10:35 PM   #10
Dejvid1785
Are you kiddin me, there is no other major fabrications? What other problems did you run into? I'm really lookin forward to doin this swap, i need all the info i can get.
