Old 10-11-2006, 07:56 PM   #1
jarek
jarek is on a distinguished road
Default warning lamp for rear lights on dashboard
I’m having problem with “rear lights” warning lamp on dashboard.
( and I did check all position and break bulbs)
When starting engine, light comes on and stays till I press break pedal for the first time.
When I turn on position or main lights, warning light is on. When breaking warning light goes off and back on.
Any idea?
jarek is offline   Reply With Quote
Old 10-11-2006, 08:54 PM   #2
dcrusupra
dcrusupra's Avatar
Theres a little yellow box under the drivers side taillight that is probably bad. Try getting a used one from the junkyard. It should solve that problem. Or one of your taillights or directionals are out.
New Rebuild
My CarDomain
Old 10-11-2006, 08:54 PM   #3
nelly26
nelly26 is on a distinguished road
Unhappy
i have u checked all bulbs at rear working including brake lights and side lights and also check fuses for rear lights also is thew battery warning light on as well
nelly26 is offline   Reply With Quote
Old 10-11-2006, 09:36 PM   #4
jarek
Default thx
I noticed this yellow box when checking bulbs.
Is this box responsible for lighting warning light on dashboard?
Old 10-11-2006, 09:37 PM   #5
jarek
Default battery
battery warning light is OK, charge ~14V when enginr running.
Old 10-11-2006, 09:45 PM   #6
nelly26
Smile
i will let you now later i have a toyota workshop manual i will read and post info for you tommorrow
Old 10-11-2006, 11:40 PM   #7
j3pz
the little yellow boxes are known to go bad so more than likely thats wat it is
Old 10-12-2006, 12:17 AM   #8
jarek
Default thx!
thx you all
LF: Lightbulbs guide lamw001 MKIV Supra 2 09-18-2008 02:23 PM
Dash lights Furious1 MKIII Supra 5 03-30-2007 05:50 PM
Dashboard lights JIMMY JAMES Non-Generation Specific Questions 7 08-17-2006 05:07 PM
