I’m having problem with “rear lights” warning lamp on dashboard.
( and I did check all position and break bulbs) When starting engine, light comes on and stays till I press break pedal for the first time. When I turn on position or main lights, warning light is on. When breaking warning light goes off and back on. Any idea? Last edited by jarek; 10-11-2006 at 07:56 PM. Reason: spell |
Theres a little yellow box under the drivers side taillight that is probably bad. Try getting a used one from the junkyard. It should solve that problem. Or one of your taillights or directionals are out.
i have u checked all bulbs at rear working including brake lights and side lights and also check fuses for rear lights also is thew battery warning light on as well
I noticed this yellow box when checking bulbs.
Is this box responsible for lighting warning light on dashboard? |
battery warning light is OK, charge ~14V when enginr running.
#6 |
i will let you now later i have a toyota workshop manual i will read and post info for you tommorrow
#7 |
the little yellow boxes are known to go bad so more than likely thats wat it is
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
My brake lights are stuck on. wtf! | Isphius | MKIII Supra | 16 | 09-07-2009 08:48 PM |
LF: Lightbulbs guide | lamw001 | MKIV Supra | 2 | 09-18-2008 02:23 PM |
Dash lights | Furious1 | MKIII Supra | 5 | 03-30-2007 05:50 PM |
Dashboard lights | JIMMY JAMES | Non-Generation Specific Questions | 7 | 08-17-2006 05:07 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
