Old 10-13-2006, 09:08 PM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Default Draining Tranny fluid
When drainind tranny fluid from the plug on the bottom of the tranny, does that drain it all or just from the pan? If it is just from the pan how can i get it all out?
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-13-2006, 09:19 PM   #2
nelly26
nelly26 is on a distinguished road
auto or manual
nelly26 is offline   Reply With Quote
Old 10-13-2006, 09:25 PM   #3
ravenmaster
Auto non-turbo
Old 10-13-2006, 09:39 PM   #4
nelly26
hi i have a workshop manual on cd for supra on all aspect of vehicle including tranny but the size of document is to big to be posted i could email to u direct if u want but i need ur email address
Old 10-14-2006, 04:30 AM   #5
tone loc
tone loc's Avatar
when you unplug the plug im pretty sure it all drains out. if you want to flush i dont know how. sorry
Old 10-14-2006, 04:51 AM   #6
ravenmaster
Hey nelly I am still waiting on that manual, also anyone have an answer to this question?
Old 10-14-2006, 04:53 AM   #7
ravenmaster
Also can anyone suggest a way to get off the refill plug off the LSD I have been sitting here with a socket wrench for the last hour and I feel weak cuz I can't get it to budge. Please help!
Old 10-14-2006, 05:11 AM   #8
dcrusupra
dcrusupra's Avatar
Use a breaker bar on the socket wrench. Or you can get a torch and heat around the plug so the metal will expand a bit.
New Rebuild
My CarDomain
Old 10-14-2006, 05:36 AM   #9
ravenmaster
Thanks I will try that tomorrow. All the stores are closed now.
Old 10-14-2006, 10:28 AM   #10
Bill UK
AEM EMS
Bill UK's Avatar
Good question I hope you get a result, I have the same problem drained about 2 to 3 litres out, made a big mistake and filled up with TQ Dextron III after a 5 mile run trany started to make a loud buzzing noise. Again drained out 2 to 3 litres and filled up with Dextron II, buzzing noise has gone but need to drain all the fluid out to make sure. The local auto shop recommended TQ Dextron III, totally wrong this is a different fluid used for the latest electronic transmissions. The trany holds 7 litres how you get the rest out I don’t know.
Amt. of tranny fluid from "cool" to "hot". go.stfu MKIII Supra 2 08-13-2007 07:05 PM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
Fluid Reccomendations. Such an improvement! ravenmaster MKIII Supra 9 10-23-2006 05:15 PM
tranny fluid tone loc MKIII Supra 9 10-23-2006 04:06 AM
W58 tranny fluid dcrusupra MKIII Supra 0 01-19-2006 03:26 AM
