Old 10-14-2006, 04:55 AM   #1
captwilddog
captwilddog is on a distinguished road
Default injectors
Ok guys i have a 86.5 supra and what i want to do is upgrade the injectors will a set out of a tubo fit it for it and will i have to change my computer are what can someone help thanks
captwilddog is offline   Reply With Quote
Old 10-14-2006, 05:04 AM   #2
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
uhhthe turbo's ijectors are the same size as the N/A. Secondly they will be old, so thats not good. No you will not have to mess with the ECU but you will have to increase the airflow. You can do this by doing the following:
1. Get a High-Flow Air Intake. I suggest the Spectre Airflow, or the K&N made for our cars. Both can ge gotten at your local Auto Store.
2. You must adjust your AFM. This is a really weird procedure. If you do it incorrectly you will have problems. You willhave to lean out the mixture. Go to http://www.well.com/user/mosk/AFM1.htm.
And follow its directions. Read EVERYTHING before you do it.
My suggestion is shell out the money for bigger injectors.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-14-2006, 05:11 AM   #3
captwilddog
i thought the 86.5 had 300cc and turbo had 440cc sry but thanks for the answer i will get bigger ones but can you recamind what size to get
Old 10-14-2006, 05:33 AM   #4
dcrusupra
dcrusupra's Avatar
Depends on how much power you want. What modification are you trying to support by using bigger injectors?
New Rebuild
My CarDomain
Old 10-14-2006, 03:10 PM   #5
burton51m
burton51m's Avatar
the injector size of an N/A is 380cc, and turbo 440cc.
Old 10-14-2006, 03:35 PM   #6
captwilddog
you are correct i looked it up after i got off last night my question is will the 44occ work on my car reason is i have 2 full sets i got from my shop and if they will work i will put them in dont cost as much that way and i get more power?
i have a bad injector right now trying to fix with the others
Old 10-14-2006, 05:13 PM   #7
kwnate
SP58GT
Bigger injectors won't make you any faster, It will probably end up running really rich and you will lose power.
Nate
Old 10-14-2006, 10:02 PM   #8
dcrusupra
dcrusupra's Avatar
That's why I asked what mod he is trying to support.
New Rebuild
My CarDomain
Old 10-15-2006, 01:24 AM   #9
Murd
Won't the different ohm resistance of the injectors of the turbo vs the N/A cause problems?
Old 01-17-2008, 11:57 PM   #10
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
Yeah the ohm rating on the new injectors need to be the same and I was told the stock injectors on a NA is 318 CC
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
1JZ 2JZ injectors trd-drifting MKIV Supra 3 11-29-2007 03:46 AM
A Few Q's on Turbo Injectors Chambers MKIII Supra 9 11-06-2007 03:26 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
what about these injectors Supraman MKIII Supra 7 01-01-2006 03:08 AM
