Old 10-14-2006, 03:30 PM   #1
burton51m
burton51m's Avatar
Default factory specs?
i blew my headgasket and it is in the shop, only b/c the guy who was going to work on it with me for free is extremely busy right now.(addition to house)
i asked him(the guy at the shop) and they said they are going to torque the headbolts down to factory specs....should i tell him to torque them down differently? if so how much?
or would it not matter b/c mine is an N/A
thanks
Old 10-14-2006, 10:16 PM   #2
dcrusupra
dcrusupra's Avatar
I'd say anywhere between 85-95 because the factory specs in the computer that they use is 58 ft lbs. And you will blow it leaving the shop, lol.
New Rebuild
My CarDomain
Old 10-15-2006, 01:23 AM   #3
Murd
I've always heard in the 70-74 range. Unless you're modded.
Old 10-15-2006, 06:34 PM   #4
sd88supra
Default so what about for a N/A?
I have an 87 NA which id like to take to the shop to get the head gasket torqued down properly before i blow it. what should an NA be torqued down to compared to a turbo? im gonna leave my NA pretty much stock.
Old 10-16-2006, 03:54 AM   #5
tone loc
tone loc's Avatar
r u getting a metal head gasket?
Old 10-16-2006, 06:02 AM   #6
Isphius
Isphius's Avatar
70 more or less on stock bolts, 100 and youll snap them. you can do 90-100 on arp bolts and over 100 on studs, But there is no need to go over 90-100. And a factory HG with 100 ft lbs and high octane fuel will take a 400 hp build fine, As long as it is tuned well and it doesnt detonate.
Old 10-16-2006, 07:44 PM   #7
burton51m
burton51m's Avatar
im not getting a MHG...
new stock headgasket
with new stock bolts
cygnus said 72ft/lb
thanks for the info
ill tell them
Supra JDM specs Lunch2000 MKIII Supra 0 10-24-2006 01:26 AM
Is there a market for a factory twin turbocharger upgrade for MKIV?? Bryan@BNR MKIV Supra 5 06-08-2006 07:46 AM
Needing Specs Fival Soyo MKII Supra 1 02-04-2006 06:04 AM
MKIV OEM Factory Stock Bypass Valve (BOV) Bullz_EyE MKIII Supra 0 01-23-2006 02:47 PM
