i cant seem to get my brake lights to go out they are on all the time now
![]() anybody know where the switch or what ever it is that switches the brake lights on when the brake peddle is pressed. |
It's at the top of the brake pedal. It may not be a bad switch, but it could be the little round rubber piece that is on the pedal to push the button in on the switch. Thats what happened to mine. I ended up buying a new switch and it turned out to be the little round rubber piece that i sucked up with the vacuum a few days earlier.
most likely what happened here switch is still good and no rubber piece on the peddle but i just adjusted it closer to the peddle and it works again.
#4 | |
![]() Quote:
you mean the brake-light under the dash-board or the back tail-light... |
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
Wilwood MKIII Rear brake kit | ARZ | Arizona Performance | 0 | 03-16-2007 07:46 AM |
Help!! major brake problem.... | bigal0043 | MKIII Supra | 18 | 04-15-2006 05:29 PM |
brake lights problem | MWoz34 | MKIII Supra | 2 | 09-14-2005 03:08 AM |
